I am facing issue to power up the air unit of herelink. It’s not responding, I plugged the connector in 2nd airunit it worked fine, So come to the conclusion issue with airunit, But when I plugged in the MicroUSB and connected with laptop it powered up and led was blinking after a couple of second, so there is some issue internally in power port of airunit.
USB alone won’t have enough power to turn on the Herelink.
It is weird that battery can’t turn it on but with USB together.
You may try to update your air unit again if possible
No it does not exceed 12.6 v, It was working earlier I have given 12v using cube kore port, One of them is working fine and other is not responding.
