Battery monitor QGC not working
I don’t know why Battery status is 0% in QGC, but Solex shows correct voltage value.
BATT_AMP_OFFSET,0.45
BATT_AMP_PERVLT,50
BATT_ARM_MAH,0
BATT_ARM_VOLT,0
BATT_CAPACITY,16000
BATT_CRT_MAH,0
BATT_CRT_VOLT,0
BATT_CURR_PIN,3
BATT_FS_CRT_ACT,0
BATT_FS_LOW_ACT,2
BATT_FS_VOLTSRC,0
BATT_LOW_MAH,0
BATT_LOW_TIMER,10
BATT_LOW_VOLT,21
BATT_MONITOR,4
BATT_SERIAL_NUM,-1
BATT_VOLT_MULT,15.3
BATT_VOLT_PIN,2
Thanks in advance.
Any suggestion?
I will see if I can look at this tomorrow. Very odd
Thanks for your reply @MadRC .
I attached a video showing battery status in QCG, SOLEX and MP in Herelink. It doesn’t work in QGC
https://drive.google.com/file/d/1avctk_4tofFNoi68KRG-_J9iTPY1rQPg/view?usp=sharing
Hi @MadRC, were you able to check if there is any problem with the software? Thank you!
Any news?
