Can Herelink be "relayed"?
Hi, Can the Herelink system be relayed in order to transmit signal around terrain? That is operate in mesh mode. I will be flying a heli in BVLOS about 3 km and part of its flight path goes over the top of a small mountain but I can probably use a multicopter with a relay unit above it.
Well you can set one Herelink up as a master and the other as a slave… Which would be a relay. I was just watching Michael’s video of doing just that. Now he says it’s over wifi. I’m just not sure if it’s Herelinks main wifi connection of the internal phones wifi. I’ll give it a try in the next couple of days and find out. I usually don’t need that kind of range flying. But with bathymetry and fresnel zone issues on the water, this would be awesome.
