Hi. I will be using solex as my default app. This is my solex settings along with my pixhawk cube orange pins for which I have connected a three axis gimbal. In solex, (I have set the wheel settings by default to RC CH : 9 and I have connected the pitch axis of my gimbal to AUXILIARY : 1 of my pixhawk cube orange pin) and (I have assigned A short press to change the wheel settings to CH : 10 and I have connected the yaw axis of my gimbal to AUXILIARY : 2 of my pixhawk cube orange pin) and (A long press is assigned as clear wheel settings to get back to CH : 9) This all are done in solex tx app in herelink. And another thing is that A short press and A long press, both the button channels are set in as toggle button and not a momentary button in herelink original settings, so will the above setup for gimbal work as I expect ? Should I set to toggle or momentary for the A short press and A long press ?
Hi. I will be using solex as my default app. This is my solex settings along with my pixhawk cube orange pins for which I have connected a three axis gimbal. In solex, (I have set the wheel settings by default to RC CH : 9 and I have connected the pitch axis of my gimbal to AUXILIARY : 1 of my pixhawk cube orange pin) and (I have assigned A short press to change the wheel settings to CH : 10 and I have connected the yaw axis of my gimbal to AUXILIARY : 2 of my pixhawk cube orange pin) and (A long press is assigned as clear wheel settings to get back to CH : 9) This all are done in solex tx app in herelink. And another thing is that A short press and A long press, both the button channels are set in as toggle button and not a momentary button in herelink original settings, so will the above setup for gimbal work as I expect ? Should I set to toggle or momentary for the A short press and A long press?
You may try to use mavlink buttons to set the SERVOx_FUNCTION to other values, to change their corresponding RCIN channel.
I haven’t tried this before so I’m not sure if this will work.
So am I right which I wrote before inn above post ?
Yes. For toggle or momentary, it is up to you.
Toggle might be easy so I will just short press a button and leave it, then with the roll wheel I can control it
I will leave the servo outputs to 0 which means that through mavlink I can control it. Then I do not need to do anything in mission planner. I just need to change the settings in solex buttons as I know that aux 9 channel on solex is aux 1 pin on my cube orange and so on
I will leave the servo outputs to 0 which means that through mavlink I can control it. Then I do not need to do anything in mission planner. I just need to change the settings in solex buttons as I know that aux 9 channel on solex is aux 1 pin on my cube orange and so on. Am I correct ? @Alvin
You’ll be using mavlink to change to parameter, so not necessary needed. Because you’ll use mavlink button to change it anyway.
Yes
You are mixing up RC IN channel and OUT channel. There is no such aux channel on Solex.
So you mean that ch:9 means aux 1 on my cube orange and ch :1- means aux 2 on my cube and so on. Am I correct ?
Yes
No. You are overthinking. You should distinguish RC channel and Servo channels. I feel like you are mixing between them.
RC channels are RC inputs from RC receivers. Servo channels are MAIN OUT and AUX out. Servo1-8 are MAIN OUT 1-8 and Servo 9-14 are AUX OUT 1-6. It’s not that complicated.
There is no solid linkage between RC channels and Servo channels. You can change their relationship to whatever you want.
https://ardupilot.org/copter/docs/parameters.html#rc7-option
https://ardupilot.org/copter/docs/parameters.html#servo7-function-servo-output-function
Thank you for helping me.
