Copter land in the middle of the flight and crush
Dear expert,
As we know Kore carrier board has it own battery current and voltage sensor.
In my hexa setup I connect battery directly to the main power pad in the kore carrier board .Use Tattu pro battery which has 22000mah and 44 volt.
I write the parameters about battery sense according to Kore carrier board documentation.
After that the voltage showing on the screen is only
37 volt and the percent showing is quite wrong I think.
What show I do to get correct voltage and current measurement?
https://docs.cubepilot.org/user-guides/autopilot/the-cube-user-manual#battery-monitor-calibration
https://ardupilot.org/copter/docs/common-power-module-configuration-in-mission-planner.html
You may still need to calibrate it slightly as normal carrier board does, due to the tolerance of parts.
