Arducopter 4 RC1, Mission Planner 1.3.7236.10299. I’ve wired up my SF11/c to the cube black and can get it working using I2C on the gps2 port. I set RNGFND_TYPE1 to 7 and address 102. That seems to be the only way it works. If I move the settings to any other Range Finder, I’ve tried 2, 3, and 4, I continue to get readings in Mission Planners Status window under sonar but Mission Planner reports range finder x is not found.
I’ve tried using serial 4 on the gps2 port but couldn’t get any readings after double checking the settings on both the sf11/c and the cube’s serial4.
My question is.why doesn’t this work with other range finder ports. Am I missing some setting somewhere?
