MP just popped up a critial error dialog and tried (unsuccessfully - to notify this forum). The MP audio is reciting this error: “Check the BRD_TYPE… failed INIT Cube Black Sensor”. I’ve been having problems with it failing to init all morning ;-). Presumably I need to stop attempting to confit it and return it to the seller? Does anyone need me to do some log dumps or anything?
Have you flashed the right firmware?
If it’s happening after flashing correct firmware, then you can contact your reseller and ask for replacement.
Please follow the info in the sticky post at the top of the group.
If your bird type is correct and the log shows an issue as per that post then speak with your reseller.
