No, unfortunately all are in use.
I think I put the orange cube on an older Board.
But I’m not happy with the situation that the older Boards are discontinued.
But beside from that I’m very very happy with all the Cube Stuff
I try again to get the here+ V2 working on can, because I need another UART.
It is not working. The here2 no problem, the new here3 also no Problem. That proofs that my settings are OK.
Of cause I switch the Here+V2 to can with the small dip. And I also try another one (I got 5 of them) and on 2 different cubes, black and orange.
Any other Ideas?
Whatever you say @philip , I always miss the one UART Port and I will never understand why you shut down the 5th port for ADSB wich is generally no use for.
I always used the Serial 5 for eg. NMEA out, OSD, Lidar etc. That all works very fine.
The Here2 and Here3 I got very easy working on CAN. No Problem
The Problem was that I never got the Here+ (2nd Generation) wich also got a CAN switch working.
I got 3 of them, all to the latest Firmware, but none of them were working in CAN, only in UART
