Is that possible to disconnect ADS-B receiver in cube orange to get extra serial port ?
No, best way to gain additional serial poets is to move items to CAN
How do you solve now the situation of ads-b out require by the FAA if you have an incompatible function? is possible to install a ping2020 instead? if we use the ping2020i that have gps could we need to remove the here+?
Please explain more what you mean. ADSB on the Cube is In only and it’s not affected by recent rule changes.
FAA do not require ADSB out. I’m not sure why you are saying that they do
