Hi community members
We have purchased a cube orange plus, it was working normal and fine, then when i connected the CAN splitter hub and connected 2 here 4 GPS for checking, the cube wont respond to usb after a power cycle. No new COM ports in device manager as well. Then when I formatted the sd card the issue resolved, i flashed a new firmware again and same issue happened. Now, even after formatting sd card the issue persists. I cannot connect my cube with pc through usb, but it works good with wifi module. But log downloading is the major issue as it takes a very lot time to download through wifi and i dont want to remove sd card to copy the logs each time after the flights. The USB cable is the one provide by an old cube orange autopilot and the same wire properly connects with other cube orange flight controllers.
Hope I can find a solution for this behaviour.
