Hi all,
Does anyone have a reference to the weights for the various cube pilot versions?
Weights for the HereLink would also be helpful.
Seems second-nature to include weight specs for a device intended to fly. I didn’t see them in the docs, but if I missed it, please point me to the page/section.
Black on the mini carrier board weighs 45 grams.
The standard is heaver. Keep in mind the sensors are weighted inside the cube and it recommended to be hard mounted.
Thanks for that weight. I figured since the cube was designed as a damped spring mass system, adding additional “damping” might actually introduce springiness or errors.
Standard carrier board + black cube is 74 grams.
Mauch is 16 grams.
Here 2 GPS 46 grams.
Here 2 GPS + FC + buzzer cable + GPS1-cable (with button) + Mauch is 151 grams.
