since Cube Red autopilot will have Ethernet access on the second connector I would like to ask you if there is any reference schematic available what should be done on carrier board to make this interface working?
There is also UART8 interface seen on second connector, but I assume that this refers to the Serial 4 interface which is available on the first connector as well?
Regarding external magnetics…can I refer to the basic reference design like shown on the Figure 11 on the page 15 in the TI’s document? Link: https://www.ti.com/lit/ug/tidues1/tidues1.pdf
I would like also to ask what is expected to be connected to the 25. pin (Timestamp rtc) of the second connector? Does need to be connected anything for properly working or can be left unconnected? What is the purpose of this pin?
What is the expected current consumption in to the pin 23 (FC_NET_VCC)?
Do pins 73, 75, 77 and 79 needs to be connected to the VDD_5V_IN_backup or this can be done by the choice? Why does cube needs to be connected to the VDD_5V_IN_backup voltage, what is the purpose in behind?
Many thanks,
Kind regards,
Dejan.
