I am attempting to get a CubeNodeEth set up with the eventual goal of running a udp connection through it. I am following the setup guides here and here. For initial setup testing have the stock arduplane 4.7.2 (fb773567) setup on a cubeOrange+ on my bench. I have configured all the parameters mentioned in the setup guides and am able to access the parameter table for the cubenodeEth. I’ve pushed 4.7 FW to the cube node (FW version 4.7FB773567).
The issue is I’m never reaching the IPs set. The NET gateway, mask, and IP messages never appear. Instead a constant stream of PPP[0]: reconnecting messages appear. I know the serial params are correctly configured and consistent between devices (SERIAL2_BAUD=12.5M, SERIAL2_PROTOCOL=48 (PPP), on the cubeNode NET_PPP_BAUD=12.5M SERIAL1_BAUD=12.5M) I’ve explicitly enabled hardware flow control on the serial 2 port (BRD_SER2_RTSCTS=1) . I’ve tried the stock GH telem cable connecting the serial port on the eth node and the telem2 port on the cube carrier as well as a cable where I manually crossed the tx/rx lines and rts/cts lines. After every attempt at a fix I did both a cold and warm reboot. Nothing has helped.
At this point I feel like I’ve tried everything and am at a complete loss.
Is there something else I am missing to get this thing set up and communicating?
