CubeOrange: Required tests after a crash
A Fixed wing UAS had a battery failure, resulting in a convergent spiral and finally its crash.
May you let me know what type of tests, parameters and metrics I can run in order to return the Cube to flight service?
Or, in case of it is not possible return to service, wich are the metrics to reject the Cube.
Thanks in advance for your help,
Reset all parameters, reflash firmware, then set it up all over again from beginning.
If everything seems normal, go for a careful controlled flight.
This won’t guarantee the Cube is still 100% perfect but at least it functions.
