# Current data on Power Brick Mini
**URL:** <https://discuss.cubepilot.org/t/current-data-on-power-brick-mini/9716>\
**Category:** Cube Autopilot\
**Created:** [23 September 2022 07:50 UTC](https://discuss.cubepilot.org/t/current-data-on-power-brick-mini/9716 "2022-09-23T07:50:09Z")\
**Posts on this page:** 1\
**Showing post:** 3
<div class="post-metadata">
**Author:** ![Truth\_T](https://discuss.cubepilot.org/user_avatar/discuss.cubepilot.org/truth_t/32/3279_2.png) [@Truth\_T](https://discuss.cubepilot.org/u/Truth_T)\
**Post date:** [24 September 2022 01:54 UTC](https://discuss.cubepilot.org/t/current-data-on-power-brick-mini/9716/3 "2022-09-24T01:54:47Z")
</div>
my battery configuration is “3” in this link :
> [@Pixhawk Cube Dual Battery Configuration](https://discuss.cubepilot.org/t/pixhawk-cube-dual-battery-configuration/9318):
> Hello all, I will use 6s LIPO 5000mah X 2 and I’m scared to burn the battery or drone when I connect the power. I heard that configuration “2” is the best. but, I have 2 battery monitors and I dont want configuration “2” because I have to buy or make “Y” cable. I do not want to make “Y” cable. is it possible to use configuration “3”? will there is no problem? I will connect “battery monitor 1” to “pixhawk cube connector power 1” & “battery monitor 2”…
you said it would be advised to run two current sensors in parrallel, but here people saying it is okay:
> **[Pixhawk Cube Dual Battery Configuration](https://discuss.ardupilot.org/t/pixhawk-cube-dual-battery-configuration/88869)**
> Hello all, I will use 6s LIPO 5000mah X 2 and I’m scared to burn the battery or drone when I connect the power. I heard that configuration “2” is the best. but, I have 2 battery monitors and I dont want configuration “2” because I have to...
_[View the full topic](https://discuss.cubepilot.org/t/current-data-on-power-brick-mini/9716)._
