Differentiate between Herelink v1.1 and Herelink v1 remote unit
I’ve about 13 herelinks from which some are older v1 and some are newer v1.1
If i pair v1 remote unit with v1.1 airunit, telem works but RC doesnt work.
So is there a way to differentiate physically or in android interface between v1 and v1.1
Thanks,
MindProbe
I have a workaround for this.
The v1.1 has a brighter screen (1000 nits) as compared to v1.0 (600 nits).
So just turn off the lights and increase the brightness to maximum for all units. You’ll see a difference in brightness.
Yes the easiest way is to check the brightness, also the v1 controller should work fine with 1.1 air units. Just make sure you update it.
