Eth not working
hello. I`m testing my new herelink air unit. I setup my raspbeery pi5 to static IP and get normal connection with air unit. After i conect this to botblox eth switch and i have no any flash on diod and raspberry lost connection. I pulled up to rpi other eth from my switch at home and it worked. Switch work normaly too. so i try to conect to air unit via eth and i failed - i have no any blinking on my eth port. how can i solve this problem?
@Michael_Oborne
Looks like your airborne switch is not compatible with the Herelink air unit, If you search for Herelink Ethernet in this forum you will see a list of devices known to work and how to wire them. There are some chipsets that work and many that do not. A Switch that does work (well did when I last tested it) is a “Cable Matters USB 3.1 to 4-Port Gigabit Ethernet Switch (USB to Gigabit Ethernet Adapter)”.
