So the solex is out. Has anyone tried to control a 3d gimbal with on screen sliders? Or how can we imply that?
The onscreen sliders don’t currently translate to the outputs.
However you can map the wheel and buttons in such as a way that allows you to change from Pitch to Yaw on the wheel. You can assign on a short press the wheel to control output 6 and on a long press output 7 for instance.
