Does the Here+ V2 rover module support UAVCAN? I flipped the switch to CAN mode inside the unit but when I do that I only get steady flickering blue LEDs, which I believe means that the unit isn’t booting.
Has anyone successfully verified this GPS using CAN?
If it’s not a difficult question to answer, is CAN support for the Here+ V2 something in the pipeline? Is it something that will likely exist sooner or later - I understand that there’s probably some third party licensing with u-blox since firmware updates are through their software rather than over Mavlink.
I have a few Here+V2 modules that we have some upcoming applications for and I’d like to know if there’s no point planning to use the rover module over UAVCAN.
Hello is it still possible to use can to connect from here+ to pixhawk orange? I just tried it and it won’t let me connect, I have here3 connect over CANbus but not here +
