Here3 not showing jamming/noise info from ublox M8P
Hello.
My company has an Here3 to put on a drone for a spoofing/jamming research use case.
I try to access the UBX MON RF message/values from u-center but it doesn’t show that data.
In CAN passtrougt mode only NMEA messages are shown, and even by accessing the UART Tx/Rx in the Here3 board i can’t get the value on u-center.
Is there a way to get the jamming Indicator + noise info from the M8P board?
in passthough mode you need to enable the message
I enabled the messages on the u-center and now I can get the info.
Thanks for the reply.
