hi, im trying to setup the base station for the RTK but it does not show any progress even after a long time. Not sure what is the issue, but i stuck at the base station setup. i’ve followed the manual from the website but still not working.
More details are needed to know exactly which is the problem.
But if your problem is related to position convergency of the base, double check the parameters you set for it. If you set them so strict, it can take hours to perform the survey-in procedure and then start sending RTCM corrections.
