Hello, i'm having some trouble with the air unit firmware update. I've plugged the unit to the computer, plugged the battery to the unit via the (5-12v) power port and started the flasher_win, but it opens up and closes with some error codes.
Here's what the CMD window shows. Am I doing anything wrong? Are there any drivers that need to be installed?
Thanks in advance.
how are you powering it? what voltage? need 7+
Hi Michael, We were using a fully charged 2s li-po, the voltage was about 8,2v when we ran the flasher app.
did you install the google adb drivers?
Yes, we did.
I had some problems running the flasher exe from a temp dir… try to put it directly in your document dir for example.
and try in a directory without any spaces in the path to it.
… or funny characters
