Hello everyone,
I’m troubleshooting a Herelink Air Unit v1.0 telemetry UART issue and I suspect the air unit UART RX pin may have been exposed to 5V due to a wiring mistake.
Setup
- Flight controller: Cube Orange+
- Connection: TELEM2
- Device: Herelink Air Unit v1.0
- Goal: MAVLink telemetry between Cube and Herelink
What happened (possible wiring fault)
I mistakenly plugged the TELEM2 connector one pin offset on the Cube side. The cable also had a broken section, and I didn’t realize the full wiring state at the time.
As a result, the Herelink Air Unit RX line might have been connected to the Cube’s +5V pin for a couple of hours.
After I discovered the issue, I repaired the cable (re-soldered) and connected everything correctly again, but there is still no communication (no MAVLink link).
Questions
- Is the Herelink Air Unit v1.0 UART RX pin truly 5V tolerant?
- I’ve seen references that v1.0 UART supports 3.3V/5V TTL, but I’d like confirmation from CubePilot/maintainers or anyone who has measured/verified it.
- If RX is 5V tolerant for logic, does that still apply if RX is tied to a constant 5V rail for a long period (hours)?
- Could that stress the input protection (clamp diode, level shifter, etc.) and kill the port?
- Because the connector was offset, it’s also possible that TX-to-TX or other pin conflicts occurred temporarily.
- In such a miswire case, which component is more likely to fail: the Air Unit UART interface or the Cube TELEM2 port?
- What’s the best way to test whether the Air Unit UART port is still alive?
For example:
- Any known LED behavior on the air unit that indicates telemetry RX activity?
- Recommended loopback test method (if possible on the air unit side)?
- Any way to verify at the Linux/Android level (logs, serial device nodes, etc.)?
- Does anyone know what UART/level-shifter/interface chip is used on the Herelink Air Unit v1.0 telemetry port?
- If identifiable, I can check the datasheet absolute max ratings and whether it’s realistically repairable.
- Is component-level repair feasible?
- Has anyone replaced the UART/level-shifter chip on the Air Unit board (hot air / rework), or is the recommended path typically RMA / replacement?
Additional info I can provide
Cube TELEM2 parameters (SERIAL2_*), baud rate, protocol, etc.
Pictures of the connector pinout and the cable (if useful)
Scope readings on Cube TX line (if that helps confirm the FC is transmitting)
Any guidance would be appreciated — especially confirmation about 5V tolerance, likely failure mode, and practical diagnostic steps.
