Hi there!
We are trying to connect MissionPlanner in a PC using mavlink2 to the Cube via the WiFi hotspot of the Herelink transmitter. We want to update the mission and change some parameters during flight but can’t do this in the small screen.
Is that possible actually?
Hi, I did it, but instead of using herelink hotspot, I conected herelink to 5.8 GHz wifi and computer to same and it worked. Then you can use your favorite application and connect via UDP.
