Hi guys , actually i have some questions about the HereLink Audio transmission.
I’m trying to transmit the audio of recorded video on monitor with the HDMI cable but it seems impossible however i have image signals and i can see the recorded video on my monitor but i can not here the voice of the video and it does not record the sound with the image . I emphasize that i use a HDMI cable for transmit the audio and image on the monitor.
Thank you all.
Hi
There is no Audio when you record video with herelink.
Best regards,
Mike
Hi
Thank you a lot for your reply, sir.
So can I use an external Microphone for this work, and if I should use a microphone, is there any special setup or driver for that?
parsa
Hi
The airunit only can receive video signal data only.
Best regards,
Mike
