I ran the new Herelink stable firmware update this morning.
I was able to perform an initial flight of around 10-15 minutes with no issues. The purpose of the first flight was to perform a new Servo_Auto_Trim since I’d added flaps and may have slightly changed the wing airflow pattern
I then took off for a flight and the ground/air units disconnected not long after takeoff.
I tried every combination of app and controller restarts but nothing seemed to work. It did connect briefly for around 5 seconds but not long enough for me to land or envoke another flight mode.
The battery depleted enough for the plane to safely land while in loiter (which I have set for both lost link and battery failsafe).
Is the air unit still hot/warm at landing? If so it had lost telemetry connection but it’s still able to controlled, but you thought that it’s lost signal and you didn’t have any control action during rtl and loiter, did you?? I was in that case!
In actualy, you could still control the plane landing safety!
i have seen a air unit that wont boot because its in a brownout, and when it gets in this state it may not recovery because the surge in startup current causes one continuous brownout. ie on my lab power supply
