Hello!
I tested the herelink a few days ago (ootb firmware) through a very populated urban area, with a bit of elevation change. The source video was from a computer. The transmitted lag was about 120 msec, and we were impressed with the quality (shout-out to CubePilot for making one of the first high quality feature packed hd fpv systems). We were able to achieve about a mile and a half of range, which is reasonable considering the amount of blockage to any kind of LOS.
As a few people mentioned that the Flir Vue Pro HDMI module (built for lightbridge/solo) did not work, I began testing a few alternative modules today. In addition, I was going to update to the latest firmware; however, weāve run into an issue - suddenly the air unit seems to have powered off. The air unit was being powered by a regulated 5v supply, and the air unit was roughly room temperature, so itās not a overheating or power issue. Anyone have ideas?
While I am still open to discussion, I just tested the air unit with a 2s battery I had around, and it is working properly. A multimeter showed the voltage on that bus occasionally dipping to 4.8v so I suspect the supply may have a failed regulator. An oscilloscope will tell. Stay tuned for analog to HDMI converter test results.
Update:
I have tested these two converters and can confirm they work as expected.
https://www.amazon.com/dp/B0771TSGVC - when viewing recorded video from the herelink frame-by-frame, this one appeared to have very slightly higher video quality but there is a significant chance that it was caused by me using a 6" cable vs the 4ā ones on the other adapter.
Update:
After some testing (to no avail) I think I have determined why the Xiaomi Yi action cams do not work with the HereLink. Regardless of what resolution and standard (NTSC/PAL) you set them to, they only output 1080i on the live feed. this may be possibly fixed by a firmware hack
Update:
I ended up using the AuviPal converter (second link) because it, when disassembled has a much smaller PCB (weighing in at 7g). Picture is in the thread below.
@philip Do you know what impedance and series the antenna connectors are for the ground unit? I would like to get some extension cables for the antennas as the position we are likely to have the herelink in is not optimal for LOS with the drone.
I recall it saying that the air unit used MMCX, but I donāt think it mentioned the connector for the ground unit. They look like Mini BNC/ High Density BNC but I think those are only available in 75ohm. If you can check whenever it is convenient for you, Iād appreciate it.
Hi, we have tested an av to hdmi converter the same as your first link to āCIMPLE COā unit. It seems to come in many brands and colors. You have to be carefull when ordering one as the same unit comes in different configurationsā¦eg you can easily select an HDMI to AV instead of the other way aroundā¦
I thought the herelink air unit was supposed to run on 12v?
Sorry for my ignorance, whatās the meaning of āootbā firmware? As Iām using the latest firmware and not able to get the Herelinkās lag lower than 230ms. Any advice on how I could achieve 120ms like yours. Thank you.
Iāve gone through a handful of websites searching, but couldnāt line it up with any datasheet/pinout. If I ever find out, Iāll let you know/post it here
