Herelink unit won't power on with 7V power in
Hi there,
Just as the topic suggests. I designed and made a buck converter to produce a 7(.06)V output to power the Herelink (1.1), and it won’t power on. Plugging it into the computer with microusb works, so it’s not like the unit is dead. I’ve tested the pins of the power-in connector and they’re showing 7.06V. What steps should I take to troubleshoot the unit? Higher voltage? My understanding was that the lower voltages in the given range were preferred.
