Hello all,
I am now using a go-pro 7 black, connected to the HDMI 1 port. It works perfectly, however the latency is 1-1.5 seconds. Is there something that can be done to solve that?
Thank you in advance.
Hello all,
That is very long, it has to be GP side, they are not always the fasted with their output but usually not that long
What settings could I modify to speed it up?
I was reading in another thread that could be because the Hypersmooth is enabled, I will try to disable it.
@abelmartinez90
That’s correct. With the Hero 7 Black, hypersmooth will add at least 1 second of latency. The latency is much lower with any other setting configuration, as long as hypersmooth is disabled.
That worked perfectly.
