High-Temperature Desert UAV Testing using CubePilot Ecosystem
Operating UAV systems in the Gulf region presents a completely different engineering challenge compared to standard environments.
We recently initiated a dedicated high-temperature desert UAV evaluation program in the UAE using the CubePilot ecosystem to assess operational stability and system behavior under harsh environmental conditions.
Current evaluation areas include:
• High ambient temperature flight stability
• Flight-controller thermal behavior under direct desert exposure
• Dust and sand effects on avionics and cooling efficiency
• Power-system thermal loading and endurance behavior
• GPS, compass, and sensor consistency during elevated-temperature operation
• HereLink communication stability under extended operational conditions
• Redundancy and fail-safe behavior during demanding missions
One of the major engineering challenges in desert environments is not only the surrounding air temperature itself, but the cumulative thermal loading generated by:
direct solar radiation,
airframe heat absorption,
internal electronics concentration,
and reduced passive cooling during hover or low-speed operation.
In some scenarios, the external airframe surface temperature can significantly exceed ambient temperature, which then influences internal avionics compartments and onboard systems.
We are currently evaluating different approaches related to:
thermal management,
airflow optimization,
avionics architecture,
shielding concepts,
and harsh-environment operational endurance.
The flexibility and modularity of the CubePilot ecosystem have been extremely valuable throughout these evaluations and system configurations.
Very interested to hear from others operating UAV systems in extreme environmental conditions.
Dr. Fares Al DHaheri
Al-Etihad Industrials – UAE
