I want to play the video on my surveillance system to record it and i don’t know how to …
May I ask what the application is?
i want to send the video stream to remote surveillance room by using an NVR and switch and a fiber optic cable to the server
If it can accept rtsp video streaming data, then that’s easy
yes it can accept rtsp but how can i transfer herelink wifi stream into ethernet cable
What should i do with the user guides first page ?
Searching in the left column to find this :
https://docs.cubepilot.org/user-guides/herelink/share-video-stream
thanks @Julien but i wanted to make it an input to a record system such as NVR and it must be ethernet cable .
Then use a USB to Ethernet adapter or a wifi bridge… same instructions apply
