Is it possible to use two cameras connected via Ethernet switch to Herelink Air 1.1 and switch between streams on the Ground Unit?
Hello everyone!
Is it possible to create a working setup with two Ethernet cameras on the drone connected via small mobile ethernet switch to the Herelink Air Unit? I have it all set up and working apart from the fact that I don’t know how to handle two video streams over the ethernet port in the Herelink and how to configure the Ground Unit to handle the two streams. I don’t really need a picture in picture feature or anything like that, just being able to quickly switch between the two streams would be ideal.
Thank you in advance!
@Michael_Oborne
this is a very custom solution.
the software on herelink is only designed to work with the video originating from the herelink hdmi port.
while what your asking i do believe is possible. it would require custom software to make it all work
Thanks for the reply. I think we will just have to reconfigure the setup to have two HDMI sources instead of ethernet, and we will be set.
