firebblade
(sokratis parsanos)
30 July 2022 10:34
1
Hello ,
I got a POWER.FLAGS 8 (overcurrent) and the gps and compass went flat (health on compass 0 Nsats 0 ) . am not sure if its the GPS unit or the CAN port on the FC or the FC it self .
https://drive.google.com/file/d/1waNKDRxj8A2ZQHzvggBYqCdZUe0nGnyD/view?usp=sharing
Is there a way i can test the the HERE3 to see if its ok ? or the CAN buss on the cube orange ?
Can someone please help with this ?
Best wishes.
firebblade
(sokratis parsanos)
3 August 2022 04:33
2
Any idea why Power,Vcc? spikes and gps stops ? what could be the issue here ? cables seem fine .
Best!
firebblade
(sokratis parsanos)
29 August 2022 14:42
3
@Alvin
Could i please get your opinion , what went wrong from the logs ?
best!
firebblade
(sokratis parsanos)
19 September 2022 15:54
4
@Mike_ZY
hello could i have some help please ?
Mike_ZY
(Mike_ZY)
26 September 2022 09:57
5
Yes,I can see a sudden increase on power.vcc.
What device did you connect on your carrier board?
Can you share your set up if you do not mind?
firebblade
(sokratis parsanos)
26 September 2022 10:47
6
Hello @Mike_ZY ,
Thank you for your reply!
i have a smart AP PDB that gives power to FC, motors, gimbal, telemetry, herelink,
on the FC i have :
the gps1 cable with the safety switch cable
i2c connected to the i2c strip board and on this 2 terrabee evo 40 & 60m
Usb with buzzer and usb cable
Telem1 with rfd900 (external power)
telem2 goes to herelink
can1 to here3
sbus to herelink
6X Main out motors 501 t-motor 2006 props
AUX Out 5 trigger for camera
Was that the info you needed ?
Thanks again for looking into this,
Best !
Mike_ZY
(Mike_ZY)
29 September 2022 02:26
7
Hi
I think might be a sudden power increase or short circuit on your device.
Can you please check that?
Best regards,
Mike
firebblade
(sokratis parsanos)
29 September 2022 03:45
8
Hello @Mike_ZY ,
How do i check that ? which device you mean the Here3?
Thank you ,
Best!
firebblade
(sokratis parsanos)
24 October 2022 09:29
9
@Mike_ZY @Alvin
Am waiting since the 30th of July for your support on the products i bough from your conpany
Can you please help understand what is happening here ?
@Mike_ZY i can see the flags that say overrcurrent
What is next ? How can i be sure that either here3 or cubeorange is not faulty
Best !
Mike_ZY
(Mike_ZY)
24 October 2022 10:05
10
Can you please check all onboard device and make sure they all functional ?
Can you operate these device one by one each time and and monitor board voltage on GCS ?
Didi connect your gps on another can port to check it?
