I am trying to get the Herelink controller to use channel 9 and 10 non the Cube to control a gimbal. The manual does not have a section that describes ho to do this. please update the manual and give any insight, you can share here.
Thanks,
Kyle
On your Herelink go to settings menu (little wheel on top of screen)
Go in ‘Buttons’ tabs and link the desired channel to a button
After that, use mission planner to configure the Cube :
Initial setup > optional hardware > Camera gimbal
Best,
Julien
I went into mission planner and was able to change CH10, where I mapped the channel on the controller, to be set a ‘1’ which is signal pass through, and that worked.
Thanks for the ideas.
