Mavlink between HereLink and RPi
I think I have a standard setup, but I don’t found any anwsers from this forum or anywhere.
(of course ChatGPT and Co. are completly dumb for this)
here my setup, (RPi means RaspberryPi)
FC <-USB-> RPi <-ETH0-> HereLink AirUnit 1.1 <-On Air-> HereLink Controller
RPi <-ETH1-> my PC (for dev purpose)
there is no link between ETH1 and ETH0, no wifi from RPi, (currently my “drone” is a cardbox)
i have setup a mavlink-routerd that allow my FC to speak with with HereLink Controller
[General]
# Debug level: error, warning, info, debug
DebugLogLevel = error
# Heartbeat state report interval in seconds
HeartbeatStateReport = 5
# Flight controller endpoint (on USB)
[UartEndpoint FlightController]
Device = /dev/ttyACM0
Baud = 115200
# RPi -> Herelink Air Unit
[UdpEndpoint herelink_air]
Mode = Server
Address = 192.168.144.84
Port = 14550
# RPi -> Herelink Ground Unit (QGroundControl)
[UdpEndpoint herelink_controller_direct]
Mode = Normal
Address = 192.168.144.11
Port = 14550
# TCP Server - allows clients to connect
[TcpEndpoint server]
Mode = server
Address = 0.0.0.0
Port = 5760
# Local monitor endpoint
[UdpEndpoint monitor]
Mode = Normal
Address = 127.0.0.1
Port = 14551
It’s almost work, but only if I start a QGroundControl on my PC (few second is enough)
otherwise, the QgroundControl on the HereLink Controller doesn’t get telemetry and don’t bind the SBUS.
But at the end, the PC should not be there, it’s only for dev purpose.
Is there something i missed or I need to do ?
It’s been days i’m on this issue
i have found a workaround for the telemetry by simulate a QGroundControl start-up on TCP connection directly in the RPi, but it’s not enough for the SBUS.
here, the solution (just a part… it’s still not work) :
[General]
DebugLogLevel = info
HeartbeatStateReport = 1
Baud = 115200
[UdpEndpoint RPi]
Mode = Normal
Port = 14550
Mode = server
Address = 0.0.0.0
Port = 5760
Mode = Normal
Address = 127.0.0.1
Port = 14551
I have now connected only the F <-UART-> HereLink
And I still have not all telemetry info.
basically, the solution is to simulate some mavlink request message to force the FC to periodically send information.
those command are normally send by the QGroundControl, but the HereLink version does not
