Mavproxy stuck at mode STABALIZE
I am getting a strange issue with TX2NX jetson. When connected the UART with Telem1 with Orange Cube Plus the behaviour is diffrenet and with Holybro 6C on telem1 it is diffferent.
This is on OC Plus metallic
sudo mavproxy.py --master=/dev/ttyTHS2 --baud=57600
Connect /dev/ttyTHS2 source_system=255
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from /dev/ttyTHS2
MAV> Detected vehicle 1:1 on link 0
online system 1
STABILIZE> Mode STABILIZE
status
STABILIZE> Counters: MasterIn:[4] MasterOut:4 FGearIn:0 FGearOut:0 Slave:0
MAV Errors: 0
None
4: HEARTBEAT {type : 2, autopilot : 3, base_mode : 81, custom_mode : 0, system_status : 3, mavlink_version : 3}
STABILIZE> status
STABILIZE> Counters: MasterIn:[10] MasterOut:8 FGearIn:0 FGearOut:0 Slave:0
MAV Errors: 0
None
9: HEARTBEAT {type : 2, autopilot : 3, base_mode : 81, custom_mode : 0, system_status : 3, mavlink_version : 3}
1: TIMESYNC {tc1 : 0, ts1 : 1780432004001}
status
STABILIZE> Counters: MasterIn:[11] MasterOut:9 FGearIn:0 FGearOut:0 Slave:0
MAV Errors: 0
None
10: HEARTBEAT {type : 2, autopilot : 3, base_mode : 81, custom_mode : 0, system_status : 3, mavlink_version : 3}
status
STABILIZE> Counters: MasterIn:[11] MasterOut:10 FGearIn:0 FGearOut:0 Slave:0
MAV Errors: 0
and this is with Pixhawk 6C Holybro
Log Directory:
online system 1
AP: ArduCopter V4.5.0 (53ad2c2a)
AP: ChibiOS: 6a85082c
AP: Pixhawk6C 0042002F 34305109 38303334
AP: IOMCU: 410 2003 411FC231
AP: RCOut: PWM:1-16
AP: IMU0: fast sampling enabled 2.0kHz
AP: Frame: QUAD/X
AP: EKF3 IMU0 initialised
AP: EKF3 IMU1 initialised
AP: AHRS: EKF3 active
AP: EKF3 IMU0 tilt alignment complete
AP: EKF3 IMU1 tilt alignment complete
AP: EKF3 IMU1 switching to compass 1
AP: EKF3 IMU0 switching to compass 1
AP: EKF3 IMU1 MAG1 initial yaw alignment complete
AP: EKF3 IMU0 MAG1 initial yaw alignment complete
STABILIZE> Counters: MasterIn:[1428] MasterOut:19 FGearIn:0 FGearOut:0 Slave:0
MAV Errors: 0
None
54: AHRS {omegaIx : 0.0010998358484357595, omegaIy : 0.0008504056604579091, omegaIz : 0.00024170652613975108, accel_weight : 0.0, renorm_val : 0.0, error_rp : 0.0009941189782693982, error_yaw : 1.0}
54: AHRS2 {roll : -0.0015033383388072252, pitch : 0.01613566093146801, yaw : 0.2503778636455536, altitude : -3.759999990463257, lat : 0, lng : 0}
53: ATTITUDE {time_boot_ms : 910335, roll : -0.0066880350932478905, pitch : 0.013848596252501011, yaw : -1.9504477977752686, rollspeed : -0.0009131124243140221, pitchspeed : -0.00036181998439133167, yawspeed : -0.00016504229279235005}
54: BATTERY_STATUS {id : 0, battery_function : 0, type : 0, temperature : 32767, voltages : [178, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535, 65535], current_battery : 531, current_consumed : 1333, energy_consumed : 8, battery_remaining : 59, time_remaining : 0, charge_state : 1, voltages_ext : [0, 0, 0, 0], mode : 0, fault_bitmask : 0}
9: COMMAND_ACK {command : 410, result : 4, progress : 0, result_param2 : 0, target_system : 255, target_component : 230}
54: EKF_STATUS_REPORT {flags : 167, velocity_variance : 0.0, pos_horiz_variance : 0.00078407465480268, pos_vert_variance : 0.005609854590147734, compass_variance : 0.004147701896727085, terrain_alt_variance : 0.0, airspeed_variance : 0.0}
150: FILE_TRANSFER_PROTOCOL {target_network : 0, target_system : 255, target_component : 230, payload : [4, 0, 1, 128, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]}
53: GLOBAL_POSITION_INT {time_boot_ms : 910335, lat : 0, lon : 0, alt : -30, relative_alt : -3763, vx : 0, vy : 0, vz : 0, hdg : 24825}
54: GPS_RAW_INT {time_usec : 0, fix_type : 0, lat : 0, lon : 0, alt : 0, eph : 65535, epv : 65535, vel : 0, cog : 0, satellites_visible : 0, alt_ellipsoid : 0, h_acc : 0, v_acc : 0, vel_acc : 0, hdg_acc : 0, yaw : 0}
19: HEARTBEAT {type : 2, autopilot : 3, base_mode : 81, custom_mode : 0, system_status : 3, mavlink_version : 3}
54: MCU_STATUS {id : 0, MCU_temperature : 4143, MCU_voltage : 3325, MCU_voltage_min : 3311, MCU_voltage_max : 3339}
53: MEMINFO {brkval : 0, freemem : 65535, freemem32 : 599016}
53: MISSION_CURRENT {seq : 0, total : 8, mission_state : 2, mission_mode : 0}
53: NAV_CONTROLLER_OUTPUT {nav_roll : 0.00023937391233630478, nav_pitch : -9.557392331771553e-05, nav_bearing : -111, target_bearing : 0, wp_dist : 0, alt_error : 3.711080551147461, aspd_error : 0.0, xtrack_error : 0.0}
1: PARAM_VALUE {param_id : STAT_RUNTIME, param_value : 404469.0, param_type : 6, param_count : 1023, param_index : 65535}
53: POWER_STATUS {Vcc : 5016, Vservo : 0, flags : 20}
54: RAW_IMU {time_usec : 910335462, xacc : 14, yacc : 5, zacc : -1000, xgyro : -2, ygyro : -1, zgyro : 0, xmag : 0, ymag : 0, zmag : 0, id : 0, temperature : 4480}
54: RC_CHANNELS {time_boot_ms : 910335, chancount : 0, chan1_raw : 0, chan2_raw : 0, chan3_raw : 0, chan4_raw : 0, chan5_raw : 0, chan6_raw : 0, chan7_raw : 0, chan8_raw : 0, chan9_raw : 0, chan10_raw : 0, chan11_raw : 0, chan12_raw : 0, chan13_raw : 0, chan14_raw : 0, chan15_raw : 0, chan16_raw : 0, chan17_raw : 0, chan18_raw : 0, rssi : 255}
54: SCALED_IMU2 {time_boot_ms : 910335, xacc : 15, yacc : 2, zacc : -1007, xgyro : -2, ygyro : 0, zgyro : 0, xmag : -125, ymag : 315, zmag : 130, temperature : 4500}
54: SCALED_PRESSURE {time_boot_ms : 910335, press_abs : 952.0481567382812, press_diff : 0.0, temperature : 4057, temperature_press_diff : 0}
53: SERVO_OUTPUT_RAW {time_usec : 910335432, port : 0, servo1_raw : 1000, servo2_raw : 1000, servo3_raw : 1000, servo4_raw : 1000, servo5_raw : 0, servo6_raw : 0, servo7_raw : 0, servo8_raw : 0, servo9_raw : 0, servo10_raw : 0, servo11_raw : 0, servo12_raw : 0, servo13_raw : 0, servo14_raw : 0, servo15_raw : 0, servo16_raw : 0}
7: STATUSTEXT {severity : 6, text : Frame: QUAD/X, id : 0, chunk_seq : 0}
54: SYSTEM_TIME {time_unix_usec : 0, time_boot_ms : 910335}
53: SYS_STATUS {onboard_control_sensors_present : 1399913487, onboard_control_sensors_enabled : 1113627663, onboard_control_sensors_health : 1198562315, load : 198, voltage_battery : 178, current_battery : 531, battery_remaining : 59, drop_rate_comm : 0, errors_comm : 0, errors_count1 : 0, errors_count2 : 0, errors_count3 : 0, errors_count4 : 0}
54: TERRAIN_REPORT {lat : 0, lon : 0, spacing : 100, terrain_height : 0.0, current_height : 0.0, pending : 0, loaded : 56}
2: TIMESYNC {tc1 : 0, ts1 : 910210316001}
53: VFR_HUD {airspeed : 0.0, groundspeed : 0.0034128616098314524, heading : 248, throttle : 0, alt : -0.029999999329447746, climb : -0.0032888592686504126}
54: VIBRATION {time_usec : 910337919, vibration_x : 0.016709597781300545, vibration_y : 0.025726819410920143, vibration_z : 0.05320805311203003, clipping_0 : 0, clipping_1 : 0, clipping_2 : 0}
Note I am using the same cable to connected to uart tx2nx — telem1 on both pixhawks (cube and holybro)
Is there some thing different in terms of specs or do we need to add something herer?
