No video in Solex app Herelink after update to 1.3.8
After update to version 1.3.8 I have no video signal from HDMI in Solex. Everything works on the same Herelink on QGC and MissionPlanner. I changed App settings “Default Vehicle Type” to Solo but that didn’t help. I tried different settings in “Vehicle type” in Solex but that didn’t help. I have telemetry connection with my copter it works without problems. I tried to clear Cache and Data in Solex app but that didn’t help :frowning:
Unfortunately we have the same issue across multiple units. 1.3.8 is killing the video feed. QGC will still work fine. At this point, I’ve given up on Solex, which is a bummer…
Any idea how to downgrade to 1.3.5 version of Solex ? This app still has some advantages over QGC.
There are a lot of things I like in Solex as well, unfortunately it isn’t supported like it should be. I wa still before there is no way to downgrade aside from wiping the remote. If you do that, your video feed will work again but die as soon as you upgrade Solex. You cannot pick upgrade versions.
Hi all, I’ve been dealing with some stuff, and haven’t been supporting Solex properly lately. I’m working on this issue, and expect to have an update available in the next couple of days. Thanks.
I pushed an update, 1.3.9, that addresses this. There is an issue I haven’t solved where I’m not getting video-stream info from the FC when I request it. But instead of simply failing, I’m falling back to a known RTSP URL and settings, so video streaming works anyway.
Kelly, thank you so much for the update!! I hope all is well on your end!
Don’t just put a random link here.
the best option is to link the official Solex release/update page or the post where 1.3.9 is announced (usually the same thread where the dev commented about the fix).
If you don’t have that, it’s better to not use a link than to use the wrong link.
