# Orange Cube is not detected anymore
**URL:** <https://discuss.cubepilot.org/t/orange-cube-is-not-detected-anymore/5025>\
**Category:** Cube Autopilot\
**Created:** [6 November 2020 18:08 UTC](https://discuss.cubepilot.org/t/orange-cube-is-not-detected-anymore/5025 "2020-11-06T18:08:42Z")\
**Posts on this page:** 1\
**Showing post:** 5
<div class="post-metadata">
**Author:** ![varunburde](https://discuss.cubepilot.org/user_avatar/discuss.cubepilot.org/varunburde/32/6804_2.png) [@varunburde](https://discuss.cubepilot.org/u/varunburde)\
**Post date:** [7 November 2020 10:34 UTC](https://discuss.cubepilot.org/t/orange-cube-is-not-detected-anymore/5025/5 "2020-11-07T10:34:27Z")
</div>
Hello, I checked the cable is working fine with other devices. A solid orange led is turned on when connected via USB as well as from power via battery. The 433 MHz radio also turn ON which is connected with ads-b carrier board.
I am sorry to interrupt I think I might have something similar kind of issue as this
> [@pixhawk orange cube does not start](https://discuss.cubepilot.org/t/pixhawk-orange-cube-does-not-start/2476/2):
> Have you downloaded the correct version ? How does it look in the comports in device manager ? I would try a Cube orange version of the daily build and then see and make sure there is the correct drivers showing. I wrote a post on the docs section to help with this. [https://docs.cubepilot.org/user-guides/autopilot/the-cube-series-firmware-and-connection-troubleshooting](https://docs.cubepilot.org/user-guides/autopilot/the-cube-series-firmware-and-connection-troubleshooting)
I was reading about bootloaders, the PX4 use different bootloader(NUTTX) then ardupilot(ChibiOS). I think I messed the bootloader that’s why the cube isn’t booting 😞.
Can you suggest something something else I can do other than the solution they had ( other than soldering ).
Thank you very much for help
_[View the full topic](https://discuss.cubepilot.org/t/orange-cube-is-not-detected-anymore/5025)._
