Positioning of the Air Unit in the copter?
I have questions regarding the location of the Air Unit and antennas in a mid-size quadcopter.
Usually, I try to move the transmitters away from my flight controller to limit interference. In the case of the Air Unit of the Herelink, it is more imposing than the components that I usually use and I have difficulty finding a location.
My questions are:
Is it possible to install the Air Unit next to the Cube (as in the attached photo) without risk?
What minimum distance should the antennas be from the Cube?
Thank you in advance for your answers !
I placed my pixhawk cube and air unit onto my plane almost same as you placed and so far it’s still fine!
Thank you for your feedback, I will be able to test this configuration !
Here is it
