Prearm check: Compass not calibrated
Hello, I will try and explain as good as i can my problem starting from the begining. First of all i had some issues with my throttle so i tried to do an ESC calibration. I did that and then i went from v4.1.o ardurover to 4.0.0 so that my firmware is more compatible with QGC V4.011. The reson i work the specific QGC is that from its GUI am able to use my Boat as multirotor giving me the option to change speed at each WP. In the past it worked flawlessly but i had some problems with the module and unfortunately i did not see it before i tried to upgrade my firmware and loose every parameter. Anyway i upload the ardurover 4.0.0 and i see that my compass HERE 2 needs recalibration. I do the calibration on all 3 compasses that i have(2 on the auto pilot and one external aka HERE2). I reboot the system and when i try to arm it says that the compass isnt calibrated. I tried every compass indivitually(without having them all in use),calibrate it and then reboot,still the same problem. I went to an even older firmware still nothing. I even freed up the RAM as the documentation say because i thought maybe it just doesnt save. Nothing. The weird thing is the compass seems fine because the direction that its pointing its the direction the boat is pointing, calibration is a success every time but the prearm check still persists. Please help, am very new to all this and i have been at this thing for 3 months trying to make it work again.
