My throttle channel is reversed and I can’t calibrate.
Is there a way to reset the calibration / reset the whole Herelink GCS to factory settings?
I would like to avoid workarounds like reversing the channel
Regards
Chris
Regards
Chris
Resetting won’t change get it, you should reverse the output In the Herelink settings with the REV option.
Calibration does not set the channel direction.
Thanks for the answer.
Where do I have to reverse the channel, in solex?
Please see this on how to reverse settings
https://docs.cubepilot.org/user-guides/herelink/herelink-user-guides/one-time-setup
