Hi Guys,
Is there anyway of having the roller wheel setup, which allows the camera to remain in the same tilt position once you release the wheel.
For example : You roll the wheel, camera reaches the desired position and you release the wheel leaving the camera in your chosen position
Depending on what gimbal you are using you can. With Alexmos you can set tilt to speed mode instead of angle mode.
Vince
(Vince)
#3
Just tried this on gimbal pitch. I dosent seem to go into speed mode and acts like angle mode. Any ideas?
Shouldn’t the proper operation of the wheel increase/decrease the signal but when released leave it at the last setting
Vince
(Vince)
#5
Perhaps this is the problem, from Alex himself.
