I recently bought HereLink v1.1 and I wonder about the following.
What are the radiation pattern and the gain of Antenna in AirUnit?
How do I connect a camera (IP camera output or HDMI) to an Ehternet port in AitUnit? And how do I set it up?
How can I copy saved video files if I use the QGC of the HereLink Controller to make video recording?
HereLink Controller’s QGC program does not respond frequently. In this case, restarting QGC will operate normally. What is the solution? FW and SW are the latest versions.
I can insert SD card into Air unit, how do I record Video input to SD card?
Thanks,
Young
