Under QT 5.12.5, by using QT Creator V4.10.0, i can build and deploy the following project: herelink-v4.0.8. (You can find it at this web address GitHub - CubePilot/qgroundcontrol-herelink) but without some qml files. For this reason you can’t execute properly this project.
I got the following messages when i build and deploy:
‘C:/Qt/Qt5.12.5/5.12.5/android_arm64_v8a/qml/QtQuick/Controls/Styles/Android/SpinBoxStyle.qml/drawables’ as QML dependency
– Skipping because file does not exist.
– Adding ‘C:/Qt/Qt5.12.5/5.12.5/android_arm64_v8a/qml/QtQuick/Controls/Styles/Android/SwitchStyle.qml/drawables’ as QML dependency
– Adding ‘C:/Qt/Qt5.12.5/5.12.5/android_arm64_v8a/qml/QtQuick/Controls/Styles/Android/TableViewStyle.qml/drawables’ as QML dependency
– Adding ‘C:/Qt/Qt5.12.5/5.12.5/android_arm64_v8a/qml/QtQuick/Controls/Styles/Android/TabViewStyle.qml/drawables’ as QML dependency
– Adding ‘C:/Qt/Qt5.12.5/5.12.5/android_arm64_v8a/qml/QtQuick/Controls/Styles/Android/TextAreaStyle.qml/drawables’ as QML dependency
– Adding ‘C:/Qt/Qt5.12.5/5.12.5/android_arm64_v8a/qml/QtQuick/Controls/Styles/Android/TextFieldStyle.qml/drawables’ as QML dependency
– Adding ‘C:/Qt/Qt5.12.5/5.12.5/android_arm64_v8a/qml/QtQuick/Controls/Styles/Android/ToolBarStyle.qml/drawables’ as QML dependency
– Adding ‘C:/Qt/Qt5.12.5/5.12.5/android_arm64_v8a/qml/QtQuick/Controls/Styles/Android/ToolButtonStyle.qml/drawables’ as QML dependency
Below all the messages reported:
Initializing deployment to Android device/simulator
Deploying to 2ae6292b
10:22:40: Running steps for project qgroundcontrol…
10:22:40: Starting: “C:\Qt\Qt5.12.5\5.12.5\android_arm64_v8a\bin\qmake.exe” C:\Users\davide.bibolotti\Desktop\QGC_herelink_v4.0.8\qgroundcontrol.pro -spec android-clang “CONFIG+=debug” “CONFIG+=qml_debug”
“which” non Š riconosciuto come comando interno o esterno,
un programma eseguibile o un file batch.
Project MESSAGE: Qt version 5.12.5
Project MESSAGE: Android Arm 64 bit build
Project MESSAGE: QGroundControl Development herelink-v4.0.8:50d975f0c 2023-06-27 20:42:09 +1000
Project MESSAGE: Debug flavor
Project MESSAGE: Using Default QtLocation headers
Project MESSAGE: Skipping support for Pairing
Project MESSAGE: Using MAVLink dialect ‘ardupilotmega’.
Project MESSAGE: ANDROID_EXTRA_LIBS
Project MESSAGE: arm64-v8a
Project MESSAGE: C:/Users/davide.bibolotti/Desktop/QGC_herelink_v4.0.8/libs/OpenSSL/android_openssl/arm64/libcrypto.so C:/Users/davide.bibolotti/Desktop/QGC_herelink_v4.0.8/libs/OpenSSL/android_openssl/arm64/libssl.so
Project MESSAGE: Skipping support for Zeroconf (unsupported platform)
Project MESSAGE: Looking for Airmap in folder “C:/Users/davide.bibolotti/Desktop/QGC_herelink_v4.0.8/libs/airmapd”, variant: “Qt.5.12”
Project MESSAGE: Skipping support for Airmap (unsupported platform)
Project MESSAGE: Taisync disabled
Project MESSAGE: Microhard disabled
Project MESSAGE: Including support for video streaming
Project MESSAGE: Adding Serial Java Classes
Project MESSAGE: This project is using private headers and will therefore be tied to this specific Qt module build version.
Project MESSAGE: Running this project against other versions of the Qt modules may crash at any arbitrary point.
Project MESSAGE: This is not a bug, but a result of using Qt internals. You have been warned!
10:22:52: The process “C:\Qt\Qt5.12.5\5.12.5\android_arm64_v8a\bin\qmake.exe” exited normally.
10:22:52: Starting: “C:\Users\davide.bibolotti\AppData\Local\Android\Sdk\ndk\21.3.6528147\prebuilt\windows-x86_64\bin\make.exe” -f C:/Users/davide.bibolotti/Desktop/build-qgroundcontrol-Android_for_arm64_v8a_Clang_Qt_5_12_5_for_Android_ARM64_v8a-Debug/Makefile qmake_all
make: Nothing to be done for ‘qmake_all’.
10:22:52: The process “C:\Users\davide.bibolotti\AppData\Local\Android\Sdk\ndk\21.3.6528147\prebuilt\windows-x86_64\bin\make.exe” exited normally.
10:22:52: Starting: “C:\Users\d\AppData\Local\Android\Sdk\ndk\21.3.6528147\prebuilt\windows-x86_64\bin\make.exe” -j8
compiling C:\Users\dDesktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGCMapEngine.cpp
compiling C:\Users\da\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGCMapTileSet.cpp
compiling C:\Users\da\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGCMapUrlEngine.cpp
compiling C:\Users\d\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGCTileCacheWorker.cpp
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGeoCodeReplyQGC.cpp
compiling C:\Users\datti\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGeoCodingManagerEngineQGC.cpp
compiling C:\Users\davi\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGeoMapReplyQGC.cpp
compiling C:\Users\davii\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGeoServiceProviderPluginQGC.cpp
compiling C:\Users\dati\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGeoTileFetcherQGC.cpp
compiling C:\Users\di\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGeoTiledMappingManagerEngineQGC.cpp
compiling C:\Users\dati\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\MapProvider.cpp
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\ElevationMapProvider.cpp
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\GoogleMapProvider.cpp
compiling C:\Users\davi\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\BingMapProvider.cpp
compiling C:\Users\davotti\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\GenericMapProvider.cpp
compiling C:\Users\davi\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\EsriMapProvider.cpp
compiling C:\Users\davide.bibolotti\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\MapboxMapProvider.cpp
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\libs\shapelib\shpopen.c
compiling C:\Users\davidti\Desktop\QGC_herelink_v4.0.8\libs\shapelib\safileio.c
compiling C:\Users\daviti\Desktop\QGC_herelink_v4.0.8\src\api\QGCCorePlugin.cc
compiling C:\Users\davidtti\Desktop\QGC_herelink_v4.0.8\src\api\QGCOptions.cc
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\api\QGCSettings.cc
compiling C:\Users\dlotti\Desktop\QGC_herelink_v4.0.8\src\api\QmlComponentInfo.cc
ctPlugins\Common\SyslinkComponentController.cc
compiling C:\Users\david\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\Generic\GenericAutoPilotPlugin.cc
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\CameraMetaData.cc
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\FirmwarePlugin.cc
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\FirmwarePluginManager.cc
compiling C:\Users\daviotti\Desktop\QGC_herelink_v4.0.8\src\VehicleSetup\VehicleComponent.cc
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\Settings\APMMavlinkStreamRateSettings.cc
compiling C:\Users\datti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMAirframeComponent.cc
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMAirframeComponentController.cc
compiling C:\Users\daotti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMAutoPilotPlugin.cc
compiling C:\Users\davilotti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMCameraComponent.cc
compiling C:\Users\daviotti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMCompassCal.cc
compiling C:\Users\daviolotti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMFlightModesComponent.cc
compiling C:\Users\daviotti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMFlightModesComponentController.cc
compiling C:\Users\dav\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMFollowComponent.cc
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMFollowComponentController.cc
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMHeliComponent.cc
compiling C:\Users\davotti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMLightsComponent.cc
compiling C:\Users\dav\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMSubFrameComponent.cc
compiling C:\Users\daviti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMMotorComponent.cc
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMPowerComponent.cc
compiling C:\Users\dalotti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMRadioComponent.cc
compiling C:\Users\davotti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMSafetyComponent.cc
compiling C:\Users\davtti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMSensorsComponent.cc
compiling C:\Users\davtti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMSensorsComponentController.cc
compiling C:\Users\davide.bibolotti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMSubMotorComponentController.cc
compiling C:\Users\davi\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\APM\APMTuningComponent.cc
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\APM\APMFirmwarePlugin.cc
compiling C:\Users\dav\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\APM\APMParameterMetaData.cc
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\APM\ArduCopterFirmwarePlugin.cc
compiling C:\Users\davi\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\APM\ArduPlaneFirmwarePlugin.cc
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\APM\ArduRoverFirmwarePlugin.cc
compiling C:\Users\davii\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\APM\ArduSubFirmwarePlugin.cc
compiling C:\Users\dai\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\APM\APMFirmwarePluginFactory.cc
compiling C:\Users\davi\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\AirframeComponent.cc
compiling C:\Users\daviti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\AirframeComponentAirframes.cc
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\AirframeComponentController.cc
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\CameraComponent.cc
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\FlightModesComponent.cc
compiling C:\Users\davtti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\PX4AdvancedFlightModesController.cc
compiling C:\Users\davi\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\PX4AirframeLoader.cc
compiling C:\Users\davi\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\PX4AutoPilotPlugin.cc
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\PX4RadioComponent.cc
compiling C:\Users\daviti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\PX4SimpleFlightModesController.cc
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\PX4TuningComponent.cc
compiling C:\Users\da\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\PowerComponent.cc
compiling C:\Users\daviDesktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\PowerComponentController.cc
compiling C:\Users\davDesktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\SafetyComponent.cc
compiling C:\Users\daviti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\SensorsComponent.cc
compiling C:\Users\davitti\Desktop\QGC_herelink_v4.0.8\src\AutoPilotPlugins\PX4\SensorsComponentController.cc
compiling C:\Users\davi\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\PX4\PX4FirmwarePlugin.cc
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\PX4\PX4ParameterMetaData.cc
compiling C:\Users\dati\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\PX4\PX4FirmwarePluginFactory.cc
compiling C:\Users\dati\Desktop\QGC_herelink_v4.0.8\src\FactSystem\Fact.cc
compiling C:\Users\da\Desktop\QGC_herelink_v4.0.8\src\FactSystem\FactControls\FactPanelController.cc
compiling C:\Users\dati\Desktop\QGC_herelink_v4.0.8\src\FactSystem\FactGroup.cc
compiling C:\Users\dati\Desktop\QGC_herelink_v4.0.8\src\FactSystem\FactMetaData.cc
compiling C:\Users\dti\Desktop\QGC_herelink_v4.0.8\src\FactSystem\FactSystem.cc
compiling C:\Users\dai\Desktop\QGC_herelink_v4.0.8\src\FactSystem\FactValueSliderListModel.cc
compiling C:\Users\da\Desktop\QGC_herelink_v4.0.8\src\FactSystem\ParameterManager.cc
compiling C:\Users\davide.bibolotti\Desktop\QGC_herelink_v4.0.8\src\FactSystem\SettingsFact.cc
compiling C:\Users\datti\Desktop\QGC_herelink_v4.0.8\src\AnalyzeView\MAVLinkInspectorController.cc
compiling C:\Users\dati\Desktop\QGC_herelink_v4.0.8\src\Airmap\dummy\AirspaceManager.cc
compiling C:\Users\dati\Desktop\QGC_herelink_v4.0.8\src\VideoStreaming\VideoReceiver.cc
compiling C:\Users\dai\Desktop\QGC_herelink_v4.0.8\src\VideoStreaming\VideoStreaming.cc
compiling C:\Users\dti\Desktop\QGC_herelink_v4.0.8\src\VideoStreaming\SubtitleWriter.cc
compiling C:\Users\dai\Desktop\QGC_herelink_v4.0.8\src\VideoStreaming\VideoStreamControl.cc
compiling C:\Users\dtti\Desktop\QGC_herelink_v4.0.8\src\VideoStreaming\VideoManager.cc
compiling C:\Users\dati\Desktop\QGC_herelink_v4.0.8\src\VideoStreaming\gstqgcvideosinkbin.c
compiling C:\Users\davti\Desktop\QGC_herelink_v4.0.8\src\VideoStreaming\gstqgc.c
compiling C:\Users\dtti\Desktop\QGC_herelink_v4.0.8\libs\gst-plugins-good\ext\qt\gstplugin.cc
compiling C:\Users\datti\Desktop\QGC_herelink_v4.0.8\libs\gst-plugins-good\ext\qt\gstqtglutility.cc
compiling C:\Users\dotti\Desktop\QGC_herelink_v4.0.8\libs\gst-plugins-good\ext\qt\gstqsgtexture.cc
compiling C:\Users\datti\Desktop\QGC_herelink_v4.0.8\libs\gst-plugins-good\ext\qt\gstqtsink.cc
compiling C:\Users\datti\Desktop\QGC_herelink_v4.0.8\libs\gst-plugins-good\ext\qt\gstqtsrc.cc
compiling C:\Users\datti\Desktop\QGC_herelink_v4.0.8\libs\gst-plugins-good\ext\qt\qtwindow.cc
compiling C:\Users\datti\Desktop\QGC_herelink_v4.0.8\libs\gst-plugins-good\ext\qt\qtitem.cc
generating C:/Users/dotti/Desktop/build-qgroundcontrol-Android_for_arm64_v8a_Clang_Qt_5_12_5_for_Android_ARM64_v8a-Debug/moc/moc_predefs.h
compiling C:\Users\datti\Desktop\QGC_herelink_v4.0.8\libs\qtandroidserialport\src\qserialportinfo.cpp
compiling C:\Users\dati\Desktop\QGC_herelink_v4.0.8\libs\qtandroidserialport\src\qserialport_android.cpp
compiling C:\Users\daotti\Desktop\QGC_herelink_v4.0.8\libs\qtandroidserialport\src\qserialportinfo_android.cpp
rcc C:\Users\daotti\Desktop\QGC_herelink_v4.0.8\qgroundcontrol.qrc
rcc C:\Users\davi\Desktop\QGC_herelink_v4.0.8\qgcresources.qrc
rcc C:\Users\daotti\Desktop\QGC_herelink_v4.0.8\qgcimages.qrc
rcc C:\Users\dati\Desktop\QGC_herelink_v4.0.8\HackFileDialog.qrc
rcc C:\Users\dotti\Desktop\QGC_herelink_v4.0.8\UnitTest.qrc
rcc C:\Users\dai\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\APM\APMResources.qrc
rcc C:\Users\davtti\Desktop\QGC_herelink_v4.0.8\src\FirmwarePlugin\PX4\PX4Resources.qrc
rcc C:\Users\davilotti\Desktop\QGC_herelink_v4.0.8\src\Airmap\dummy\airmap_dummy.qrc
lrelease C:\Users\daotti\Desktop\QGC_herelink_v4.0.8\localization\qgc_pt_PT.ts
lrelease C:\Users\daotti\Desktop\QGC_herelink_v4.0.8\localization\qgc_es_ES.ts
lrelease C:\Users\daotti\Desktop\QGC_herelink_v4.0.8\localization\qgc_ru.ts
lrelease C:\Users\daotti\Desktop\QGC_herelink_v4.0.8\localization\qgc_de.ts
Updating ‘.qm\qgc_pt_PT.qm’…
Generated 0 translation(s) (0 finished and 0 unfinished)
Ignored 2736 untranslated source text(s)
lrelease C:\Users\dti\Desktop\QGC_herelink_v4.0.8\localization\qgc_he.ts
Updating ‘.qm\qgc_es_ES.qm’…
lrelease C:\Users\dtti\Desktop\QGC_herelink_v4.0.8\localization\qgc_el.ts
Updating ‘.qm\qgc_ru.qm’…
Generated 16 translation(s) (16 finished and 0 unfinished)
Ignored 2720 untranslated source text(s)
Updating ‘.qm\qgc_de.qm’…
Generated 1 translation(s) (1 finished and 0 unfinished)
Ignored 2735 untranslated source text(s)
lrelease C:\Users\davlotti\Desktop\QGC_herelink_v4.0.8\localization\qgc_fr.ts
lrelease C:\Users\datti\Desktop\QGC_herelink_v4.0.8\localization\qgc_uk_UA.ts
Updating ‘.qm\qgc_he.qm’…
Updating ‘.qm\qgc_el.qm’…
lrelease C:\Users\daotti\Desktop\QGC_herelink_v4.0.8\localization\qgc_sv_SE.ts
lrelease C:\Users\dotti\Desktop\QGC_herelink_v4.0.8\localization\qgc_bg.ts
Updating ‘.qm\qgc_fr.qm’…
lrelease C:\Users\dtti\Desktop\QGC_herelink_v4.0.8\localization\qgc_nl.ts
Updating ‘.qm\qgc_uk_UA.qm’…
Generated 2734 translation(s) (2732 finished and 2 unfinished)
Ignored 2 untranslated source text(s)
lrelease C:\Users\dtti\Desktop\QGC_herelink_v4.0.8\localization\qgc_pl.ts
Updating ‘.qm\qgc_sv_SE.qm’…
lrelease C:\Users\datti\Desktop\QGC_herelink_v4.0.8\localization\qgc_en.ts
Updating ‘.qm\qgc_bg.qm’…
lrelease C:\Users\dtti\Desktop\QGC_herelink_v4.0.8\localization\qgc_ja.ts
Updating ‘.qm\qgc_nl.qm’…
lrelease C:\Users\daotti\Desktop\QGC_herelink_v4.0.8\localization\qgc_tr.ts
Updating ‘.qm\qgc_pl.qm’…
Updating ‘.qm\qgc_en.qm’…
Ignored 2403 untranslated source text(s)
lrelease C:\Users\datti\Desktop\QGC_herelink_v4.0.8\localization\qgc_it.ts
lrelease C:\Users\dti\Desktop\QGC_herelink_v4.0.8\localization\qgc_fi.ts
Updating ‘.qm\qgc_ja.qm’…
lrelease C:\Users\datti\Desktop\QGC_herelink_v4.0.8\localization\qgc_ko.ts
Generated 2778 translation(s) (2778 finished and 0 unfinished)
Updating ‘.qm\qgc_tr.qm’…
Generated 2523 translation(s) (2523 finished and 0 unfinished)
Ignored 213 untranslated source text(s)
lrelease C:\Users\davtti\Desktop\QGC_herelink_v4.0.8\localization\qgc_zh_CN.ts
Updating ‘.qm\qgc_it.qm’…
lrelease C:\Users\datti\Desktop\QGC_herelink_v4.0.8\localization\qgc_no.ts
Updating ‘.qm\qgc_ko.qm’…
Updating ‘.qm\qgc_fi.qm’…
Generated 2733 translation(s) (2733 finished and 0 unfinished)
Ignored 3 untranslated source text(s)
Updating ‘.qm\qgc_zh_CN.qm’…
Generated 2724 translation(s) (2724 finished and 0 unfinished)
Ignored 12 untranslated source text(s)
moc C:\Users\datti\Desktop\QGC_herelink_v4.0.8\src\QtLocationPlugin\QGCMapEngine.h
Updating ‘.qm\qgc_no.qm’…
Finally debugger stops in this way:
etc etc
