I can change settings via MP connected over UDP no problem. That said, the herelink shows a red dbi meter in the upper right with an exclamation mark, and when I try to arm (in solex) I get an “error 4”. It also has blank telemetry for every other parameter. I know the connection is good as I can do everything from MP on my laptop no problem and see all the telemetry. Any idea what’s going on?
I DM’d Kelly about it. It ended up fixing itself? I’m still curious what the red dBi meter means.
On HereLink, the signal-strength indicator displays the signal level reported by the air unit. Not sure why it’s showing red if you have good signal. Error 4 means “denied”, basically the autopilot is refusing to perform the requested command.
