Used Herelink Blue 1.1 Controller Registration Key solution
If you are like me and have recently had your drone business gutted due to new regulations and are trying to literally rebuild your business. Then you might have found yourself looking at Blue rated devices and exploring the used market to avoid having to take out a second mortgage.
After I receive my controller and air unit I wanted to make sure I had all of my devices running the newest firmware. I started searching and came across the tutorial that walks you through the steps, including activating the controller after a software update. The only problem is that I didn’t have a sticker with a key on the back of my device. I had a unit that was currently working with old firmware and I was afraid that if I updated it without the key I wouldn’t be able to use it anymore.
Here’s the solution, which I found on the NW Blue website, the Blue units don’t have a sticker, they automatically populate the key when you get to the registration page. I probably should have looked at the NW Blue website to start, but I made the assumption that they would follow the same setup protocol.
Hope this helps someone.
