# Wifi connection problem
**URL:** <https://discuss.cubepilot.org/t/wifi-connection-problem/2852>\
**Category:** HereLink\
**Created:** [17 February 2020 10:24 UTC](https://discuss.cubepilot.org/t/wifi-connection-problem/2852 "2020-02-17T10:24:07Z")\
**Posts on this page:** 1\
**Showing post:** 7
<div class="post-metadata">
**Author:** ![Davidboulanger](https://discuss.cubepilot.org/user_avatar/discuss.cubepilot.org/davidboulanger/32/1040_2.png) [@Davidboulanger](https://discuss.cubepilot.org/u/Davidboulanger)\
**Post date:** [21 February 2020 12:16 UTC](https://discuss.cubepilot.org/t/wifi-connection-problem/2852/7 "2020-02-21T12:16:34Z")
</div>
> [@Herelink offline map loading instructions](https://discuss.cubepilot.org/t/herelink-offline-map-loading-instructions/2057):
> I thought I would share instructions for offload map loading into Herelink - that worked for me at least. You will need QGroundControl and working adb tool in your laptop/PC. Also microUSB cable is needed - to connect Herelink GCS to laptop/PC. Here is an brief outline of this process: download offline maps in laptop/PC QGC instance export offline maps from laptop/PC QGC instance upload export file to Herelink GCS via adb (USB) connection import file into QGroundControl in Herelink Step-by-…
_[View the full topic](https://discuss.cubepilot.org/t/wifi-connection-problem/2852)._
