Hm. Did you install exactly this driver?:
I had to do it manually as Windows always said the driver was up to date, but it was not the correct one.
I used the freeware tool „DriverStoreManager“ for driver installation. Immediately worked then.
I understand that you managed to update the ground unit via WiFi. So you only need to update the air unit, right?
