If you calibrate the Herelink like it needs to be at first calibration & setup (with the little wizard assistant) it would fully automatically set all sticks in the the right direction, it takes only one minute.
Trust me, i installed a lot of Herelinks on many different drones and configuration, i never had a reversed stick thanks to this. This little tool make me much more confortable for first flights !
My herelink radio calibration doensât work. Also not the proposed solution to keep the throttle low when you have to keep it high. And I canât reverse throtlle in mission planner either.
Running arducopter v4.0.3
And updated the herelink rx and tx firmware
Still no luck
