We are UAS at UCLA, a group of 35+ hardworking UCLA students currently competing in the First Responders Challenge. The First Responders Challenge is a competition where groups draft proposals and build systems for long endurance unmanned aerial systems to be used by first responders as communication stations. We are so grateful to have the support of CubePilot for our hybrid gas and electric drone submission, it is essential that our drone maintains an extremely accurate position to act as an effective way station, making both the Cube Orange and RTK GNSS systems extremely useful for our application. Below I give instructions on how we used the Cube Orange and RTK system setup with PX4, as while there is a lot of documentation for using it with ArduPilot, we found it more difficult to find instructions for PX4 usage.
The following instructions were performed on a Linux machine running Ubuntu 20.04, some small changes in commands may be necessary when running with different linux distributions/package managers.
*The RTK system originally would sporadically go undetected when using PX4, after updating to the latest version we noticed that this issue seemed to disappear. If you notice this problem make sure that you are running the latest firmware version.
Download PX4 from the source repository:
git clone GitHub - PX4/PX4-Autopilot: PX4 Autopilot Software
Ensure that you have installed the proper build tools (cmake and ninja), just using cmake led to a slow build. Install ninja using:
apt-get install ninja-build
Now compile PX4 for the CubePilot Cube Orange with the command:
make cubepilot_cubeorange
Then deploy to the cube (connected over USB) using:
make cubepilot_cubeorange upload
After plugging in the RTK system and the CubePilot cube you will need to configure the proper parameters for the GPS to be detected.
UAVCAN_ENABLE = 2 (Sensors Automatic)
GPS_1_CONFIG = 0 (Disabled)
Restart the FCU and you should notice the device is now detected; hopefully everything should be working at this point.
Below is a video of a test drone (not our competition submission drone as this has yet to be fully fabricated) following waypoints using PX4, the CubePilot Cube Orange and Here3 RTK GNSS to validate the system.
Follow our progress on our website: uasatucla.org
